John Deere Model B
Thomas Moje
06-10-2002 09:23:25
I have a 1944 John Deere Model B (rowcrop); hand start. I recently installed new clutch disks, and since doing so, have a problem with the clutch 'grabbing' in reverse only. That is, when trying to back up the tractor, as soon as the clutch lever is advanced far enough to just engage the clutch, the clutch 'jumps' into full engagement. In other words...almost impossible to partially engage the clutch in reverse...it's either no engagement or fully engaged...no 'half way'. Very disconcerting to say the least and could be downright dangerous (such as backing into a wall in the barn!) Oddly enough this does not occur when the transmission is in any of the forward gears-just reverse. I'm hoping this is just a clutch adjustment issue or the brand new friction disks have to get 'worn in'. Any ideas? Thanks.
Bob Weber
06-10-2002 09:47:16
 Re: John Deere Model B in reply to Thomas Moje, 06-10-2002 09:23:25
I've got to agree with puller. I was noticing the same thing on mine, and just discovered that it was the fact that, when the tractor starts moving backwards, inertia causes your body to move towards the front of the tractor a bit causing you to unconciously engage the clutch a bit more.
Deere Puller
06-10-2002 09:41:36
Make certain that your adjustment is done with the clutch in the 'engaged' position and that each of the three nuts are tightened evenly. You may have oil or grease on the friction discs / driving disc / pulley facing surface, as this causes a dry clutch to 'jump'. The problem is probably amplified in reverse as the 'jump' back forces you into the clutch lever a little harder. If it worked OK before the overhaul & now gives troubles, the mechanicals are probably sufficient for use, just out of adjustment or not clean.
Thomas Moje
06-10-2002 10:35:26
 Re: Re: John Deere Model B in reply to Deere Puller, 06-10-2002 09:41:36
Thanks folks! After reading replies to my inquiry about JD B clutch adjustment, it dawned on me that I adjusted with clutch unengaged! I will re-do adjustment with clutch engaged as per the correct method...hopefully that will work as that is an easy fix!
