Soldering Carb. Float
Jim
06-09-2002 15:29:25
What type of solder works best for re-attaching a carb float to the tab?
Booger Bob
06-10-2002 09:58:03
 Re: Soldering Carb. Float in reply to Jim, 06-09-2002 15:29:25
I've used acid core as well with good success. I've not ever used silver solder, but was under the impression that you had to use more heat to get it to melt and flow. Too much heat on a float can cause you lots of problems.
Tractorboy
06-09-2002 17:28:53
did 1 the other day with acid core soldering iron it did fine . If you get too much heat it will come apart on you .
dave
06-09-2002 15:58:07
silver solder
