970 power steering
Mike M
06-05-2002 09:58:46
Just recently bought a 1991 970, about 4500 hrs. Seems to have developed very sloppy steering. At + or - 2000 rpm, going into or out of a (tight) turn, the steering wheel feels like it is free wheeling. Many many turns on the steering wheel will not straighten out the tractor, or allow me to get into a turn. At lower rpm stopped, the wheel will turn the tires just fine, maybe alittle notchy. Receive the tech manual from Deere and checked out the procedure for the steering cylinder. I'm not seeing any blow by on the cylinder piston. None of the other 'symtoms' listed for valve or pump seem to match what I'm seeing. Is there a check valve somewhere that may be weak allowing geroter pressure to just dump to return? Kinda stumped! and this is my first tractor.
