420 utility model tractor cerca 1957/8
dan simmons
12-14-2003 17:33:48
I would like to know how to set/adjust my carburetor. There is a value on the bottom bowl and I believe two screw jets- not sure which is fuel and/or air.
Thanks ds
danny
12-14-2003 18:11:46
 Re: 420 utility model tractor cerca 1957/8 in reply to dan simmons, 12-14-2003 17:33:48
the ajustment on bottom is gas amount setting the top setting is air on mine when i go up on one i go back on other hope this helps
Wayne in Tn.
12-14-2003 18:10:22
Dan, start by having the tractor running at wide open throttle. Turn the L shaped screw on the bottom of the carb. IN until the engine sputters, then back it OUT one turn. This is the "power or gas,load screw"
Then adjust the top screw for best idle, this is the "air" needle.
The idle speed screw is behind the carb. next to the engine.
This will get you a starting point and will be very close, you may have to 'tweak' it some for hard pulling or black smoke.
