50 3pt and remote cylinder
Jdman
06-05-2002 07:49:26
I have a John Deere 50 and I was wondering if I could run the remote cylinder with a 3pt. hitch mounted on the tractor. If I can is there something I have to do to the 3pt.
Tye
06-06-2002 03:26:50
 Re: 50 3pt and remote cylinder in reply to Jdman, 06-05-2002 07:49:26
Go to jd40.com
Jhill
06-05-2002 12:47:03
you can have the 3 pt mounted but you cannot use it. It take dead plugs for the 3 pt to work and hose couplers a remote cylinder. The 2 route the hydraulic fluid differently so only one will work.
Jdman
06-05-2002 17:37:02
 Re: Re: 50 3pt and remote cylinder in reply to Jhill, 06-05-2002 12:47:03
How would I use the remote cylinder if a 3pt is on? The remote cylinder is run with the same lever as the 3pt.
Fudd
06-05-2002 20:04:18
 Re: Re: Re: 50 3pt and remote cylinder in reply to Jdman, 06-05-2002 17:37:02
There is a screw on the left side of the powertrol housing under a hex cap. Once you have the hoses hooked up, you turn this screw all the way in. The cylinder will work but the rockshaft will not. It's all explained on page 48 of the operators manual.
