'45 JD B
Spraying Oil/Gas Out Stack
Jon E - Michiga
06-04-2002 18:16:52
This weekend I tried to start a '45 JD B for the first time in 2 years. It has never turned over easily in the past so it is usually pull started. When pull started this time, a cream color liquid sprayed out the stack everytime the transmission was engaged (never started). I'm assuming the liquid is a gas/oil mixture based on its smell, texture and color. Does anyone know the cause? How about a fix to get her running again?
The carb was removed and cleaned prior to starting. Magneto was replaced 3 years ago and is functional and clean. Any help appreciated.
Kerry
06-04-2002 19:58:53
 Re: '45 JD B - Spraying Oil/Gas Out Stack in reply to Jon E - Michigan, 06-04-2002 18:16:52
Cream-colored usually means water/oil, not oil/gas. Check the oil to see if it looks like that too, it may have gotten water in it while it was sitting. Did you have antifreeze in it? Hope it's not a cracked block or head, but you probably should check.
If you get it running, smell the water and see if it smells like exhaust or gas fumes. That's bad news. These things have a lot of places that water can get in over time, so maybe that's all it is.
Good luck!
Kerry
JOHN BRAWNER
06-04-2002 21:03:01
 Re: Re: '45 JD B - Spraying Oil/Gas Out Stack in reply to Kerry, 06-04-2002 19:58:53
SOUNDS LIKE SHE IS STOPPED UP!! TAKE OFF THE PIPE THAT GOES TO THE AIR CLEANER,THE ONE THAT BOLTS TO THE CARBURETOR AND TRY STARTING IT !MUD DABBERS ARE KNOWN FOR THIS,THEY LIKE TO PLUG AIR STACKS WHICH WILL MAKE OLD TRACTORS DO SOME CRAZY THINGS,IT HAS HAPPENED TO ME MORE THAN ONCE!JUST MY GUESS!JOHN
