JD 40 Hi Crop
Daniel
06-04-2002 17:33:02
How do you distinguish a 40T from a 40 High crop?
IS it just bigger wheels or do they have the offset higher axle? Any help would be appreciated.
Thanks,
Daniel
BMeyer
06-04-2002 18:27:23
 Re: JD 40 Hi Crop in reply to Daniel, 06-04-2002 17:33:02
The biggest difference will be several thousand dollars.
The 40T will have a serial number plate that says '40T'. Some 40T's might even have the wide frontend. The rear wheels are 34" allowing for a 21" clearance.
The 40H will be much taller and have 32" clearance with 38" rear rubber.
You can view pictures of the 40T and a 420H on the link below. That should answer some questions quickly for you.
Hope this helps.
BMeyer
