3 point hitch problems
Bob
06-04-2002 16:05:33
I have an older model 4020 Diesel. The 3 point hitch will raise on it's own, but does not have enough power to lift anything else. Hydraulic fluid is at the proper level.
Any suggestions? How much of a mechanic would I need to be to fix it?
Thanks!
Steve - IN
06-04-2002 16:28:40
 Re: 3 point hitch problems in reply to Bob, 06-04-2002 16:05:33
Bob,
Before you go testing your mechanical abilities, you might want to change the filter and clean the intake screen. That should be covered in the owner's manual.
If that's no help, it gets trickier from there. You might want to get a service manual and check the flow control adjustment, the cam follower adjustment.
If those are OK, you're in for some work. Either the pump itself or the rockshaft O rings or seals have a problem.
Good luck... hoping for an easy fix...
Steve
