JD 40 Plugs---What's the correct number?
Dave
06-04-2002 13:18:26
Long story...but can anyone help with the correct JD plug? I still have the originals, but am having a tough time locating locally with the correct thread length !
Thanks
Dave
Wayne in Tn.
06-04-2002 13:58:49
 Re: JD 40 Plugs---What's the correct number? in reply to Dave, 06-04-2002 13:18:26
Dave, if you want to use Autolites, the number is 216.
Bguy
06-04-2002 17:36:42
 Re: Re: JD 40 Plugs---What's the correct number? in reply to Wayne in Tn., 06-04-2002 13:58:49
Wayne, Does the 430 use the Autolite 216 also?
Wayne in Tn.
06-04-2002 19:15:21
 Re: Re: Re: JD 40 Plugs---What's the correct number? in reply to Bguy, 06-04-2002 17:36:42
Yes, I use them in the 40-420 and 430. They seem to not foul as bad for me. For example, the other day I started one of the 430's up and had the choke all the way out. It started right up, but noticed it was running rough. let it run a few minutes while doing something else and it still was running badly. For some reason I had forgot to put the choke off.(must be old age) Pushed it in and it ran perfect. Other plugs I have used would have fouled out under a circumstance like this.
Bguy
06-05-2002 07:26:00
 Re: Re: Re: Re: JD 40 Plugs---What's the correct number? in reply to Wayne in Tn., 06-04-2002 19:15:21
Thanks, I looked in the manual and all it mentioned was the Champion number.
mike
06-04-2002 18:26:54
I run autolite #216 in all my upright 2cyl. and #388 in the rest that are styled.I used whatever I could find in the unstyled I think champion. I try not to use champion because I hear so much bad rap on them. But I have used some and can't notice a problem. I can buy autolite in a higher heat range cheaper around here.
JD Bill
06-04-2002 21:54:04
 Re: Re: Re: Re: JD 40 Plugs---What's the correct number? in reply to mike, 06-04-2002 18:26:54
I have a 420 and use Champion H-12 with 2 gaskets under it to raise the heat range. What Autolite would you recommend for a 420. With the champions I am getting a hickup/backfire through the carb.
