John Deere 500 Tractor w/Loader Bucket
Sparky
06-04-2002 05:55:53
I am interested in the history of the JD 500. When was it built, horse power, primary useage, etc. It is a diesel. Is it worth picking up?
mike
06-04-2002 12:27:00
 Re: John Deere 500 Tractor w/Loader Bucket in reply to Sparky, 06-04-2002 05:55:53
I have used one of these they are a heavyduty
unit sometimes too heavy.For most uses I have found a 4020 ag tractor more useful as the front end is lighter and can put on wider tires so it doesn't sink in.I have a 3point hitch witch our 500 did not have some do though.I have a pto and my 158 loader lifts the same amount.It is hard to get enough weight on the back end of a tractor without a 3pt hitch to hang it on. I also find the syrorange tran. better to shift
into and out of park on hills than a powershift.
Brandon
06-04-2002 07:19:28
I have some information about the JD500 at the website below. It can be either gas or diesel, and is based on the agricultural 3020.
I'm no expert, but it should be a good buy if the price is right, and it's not worn out/beat up too bad.
If you have any pictures or a serial number, could you email them? I don't have alot for the 500.
Good luck,
Brandon
