Carb Float Setting (again)
50man
06-03-2002 19:51:42
My I&T manual says the float setting on my 50 (gas)should be 3/4" from the "nearest face of the float to the needle boss". Looking at it with the bowl off I'm assuming they mean from the bottom of the float to where the valve goes up in and check this distance while pushing up on the float(like there is gas in it).If any adjustment is needed I assume just bend the float up or down?How are my assumptions?
Seamo
06-03-2002 20:54:35
 Re: Carb Float Setting (again) in reply to 50man, 06-03-2002 19:51:42
50man. Here goes out of the John Deere Carb service manual.With the carb held upside down with the float valve seated. When properly adjusted the float will be parallel with machined surface of carb body.There will be a distance of 3/4 in.from bottom of float to the machined gasket surface(or btm. of groove for bowl gasket. When they say btm of float they mean highest part of float use two small straight edge to measure. You can bend float arm to get it perfect but be careful. If I get one that is way off I use thicker or thinner gasket under the carb seat. I was the one who posted the carb test can SAT. Earl
50man
06-04-2002 17:19:33
 Re: Re: Carb Float Setting (again) in reply to Seamo, 06-03-2002 20:54:35
Thank you for the info-I understand it now!
