Gas in crankcase
Tye
06-03-2002 15:16:13
After checking the oil in my 50, I noticed that the oil was thinned out and smelled like gas. Can anyone help identify the reason why I might have gas in the crankcase?
Clooney
06-03-2002 15:58:47
 Re: gas in crankcase in reply to Tye, 06-03-2002 15:16:13
Tye, if it has an oil pressure activated fuel shut-off [you can tell by it having a diaphragm above the sediment bowl & an oil line running to the fuel strainer], that is probably the cause, [with time & the use of modern gas with alcohol in it, the diaphragms tend to leak, then the gas flows down the oil line into the crankcase. To test, pull the oil line off & let the tractor sit for a while then see if gas is dripping from the oil line. The diaphragms are, [or at least were still available from Deere]
~If you don't have an oil pressure activated fuel shut off you could have a leaking needle & seat, fuel logged carb float, plugged carb bowl vent or?
Thank you, Clooney.
06-03-2002 17:53:01
 Re: Re: gas in crankcase in reply to Clooney, 06-03-2002 15:58:47
Thank you Clooney very much for your help. Have a great day and God bless! --Tye
