How to check timing on a styled model A
mark
06-02-2002 22:24:55
I am trying to see if the timing is close on my friends tractor..also how to check engine oil level ..also under the valve cover is the rocker assembly that has a tube for oil running to the rocker assembly and then to the head ....there is a round peice that bolts to the head that has the matching end of tube ..but I noticed at the bottom of it where it bolts to the head,that there is part of the hole still showing from the head ..is that normal or is there something not right ?Is that supposed to have oil pumping from it it when it is running or somekind of drain hole ?thanks ..mark
