Hard starting jd h
abe
06-02-2002 18:07:20
my 42 h is always a pain to start/mag is rebuilts
cap/rotor/wires/plugs new/head rx/gov weights new/
fuel lines new.card rx/once running runs great/
does puffs smoke whe nrunning/comp seems good
although have not measured/
it is hand start/the timing gear marks are right on
thanks for any and all help
mike
06-02-2002 18:30:13
 Re: hard starting jd h in reply to abe, 06-02-2002 18:07:20
Have you replaced the manifold gasket ? I have had a couple of H's that had a vacume leak and were hard starting , I think that they were also needing to run with the choke on a little to keep them going. Try spraying oil or WD-40 around intake area of manifold at head area and see if it sucks it in and runs differant.
