Cutoff Axle's
Leon
12-14-2003 14:59:21
I have just finished a restoration on a 1948 AW. I guess I can"t say I have finished it since I have a Problem with the axle's. Apparently this Tractor was A wide axle.. The previous owner must have shortened the axle's with a acetylene torch as it is very uneven. I have tried to grind it off with a grinder but it is very hard steel. I'm open to any suggestions. I don't want to change them out.. I would consider using something as a hubcap. Any ideas.
chris
12-15-2003 17:29:21
 Re: Cutoff Axle's in reply to Leon, 12-14-2003 14:59:21
While working at a dealership, a local cattlefeeder needed his axles shortened on a 4450 and later a 7700 tractor. We supported the rearend and put the tractor in a slow gear, then using a small bench and a 14 inch cutoff saw we cut the axles off. These tractors pulled the feedwagons along cement fenceline feedbunks. chris Then of course he traded the 7700 in for a 7710 and guess who had to swap the axles and wheels between the two tractors.
Dennis
12-15-2003 11:10:27
Leon,
Does your tractor have the A3271R casting # on the rear axle housing? If so, it did have long axles. If not, it is not an AW but simply a regular row-crop Model A with a wide front, and did not have long axles.
Dennis
Duane Larson
12-14-2003 16:26:00
Leon,
Your AW probably had a hay lifting/stacking device, and some part of the lift attached across the back of the tractor. The axles were in the way of the lifting arms, so out came the torch and they got cut off. Hard to tell if your tractor had extra long axles or not, as it is not unusual to run into cut axles on a wide front JD, especially one from hay country.
Denny Foster
12-14-2003 16:04:15
I have got a Milwalkee Porta Band, hand held band saw that I use, does a nice job kinda slow. I have not used it on a tractor axle though. I have cut a car axle with it with good results.
Denny
Brokenwrench
12-14-2003 15:55:28
If you have access to one, a gas powered cutoff saw works wonders, takes about 1 minute with a good quality steel cutting blade, then dress it up as Clooney says.
Clooney
12-14-2003 15:25:50
Leon, years ago I had a tractor with cut-off axles, same thing as yours, either a torch or axe was used..
~I removed the wheels, then with the tractor's rear end supported I ran the tractor in gear & used a 10" disk grinder on the ends of the axles with the axles spinning.. That took a few hours & a couple of disks but left the axles flat & smooth on the ends.. I then used a V square & marked the axles for center, then used a large starter drill to put the live center holes back in.. Then with the axles spinning again I chamfered the spline ends with a smaller 4" grinder.. When they were painted black you couldn't tell those axles were ever cut off..
~One good thing about that axle steel it does grind pretty easily do to being somewhat hard....You just need a good heavy duty grinder & a few good disks..
[email protected]
moline
12-14-2003 17:19:21
 Re: Re: Cutoff Axle's in reply to Clooney , 12-14-2003 15:25:50
We have a slant dash row crop A that has cut axles.The fellow we got it from said he cut them because it was too wide to fit in the corn crib.He used a torch(looked like a beaver with dentures got at it).We used a grinder and a lot of discs to flatten it and chamfer the end of the axle,like Clooney said.We never thought of putting in the live centers though,nice touch!! Moline
Crum
12-14-2003 18:33:46
 Re: Re: Re: Cutoff Axle's in reply to moline, 12-14-2003 17:19:21
A fellow brought in a pair of axles a few weeks ago with the same problem. I just chucked them up in the lathe and dressed them up like they came from the factory. Took about 2 1/2 hours including set-up time and coffee between axles.
