Help with fasteners
F-I-T
12-14-2003 14:35:57
A long time ago, one night on second shift at the shop, a friend of mine brought in a little gadget that would install blind nuts into a hole in 16 ga and larger metal. You would thread the special nut onto a mandrel, and then as I recall, you would "spin" it, and roll an edge on the nut which trapped in place.
Does any one know what such a gadget is called and where one could be bought? I have a need to install several of blind nuts, and thought it might be handier than tinnerman nuts.
Thanks!
Frank-in-Tallahassee
70D // 855 // VAC
[email protected]
F-I-T
12-14-2003 17:05:49
 Re: Help with fasteners in reply to F-I-T, 12-14-2003 14:35:57
Okay, Thanks guys.
I found several sources. Now, if you were going to attach light gauge sheet panels to 1/8" thick brackets, would you use Steel or Aluminum rivnuts? I'm sure the steel is more durable, but aluminum is probably easier to install.
Thanks!
Frank
Clooney
12-14-2003 18:55:50
 Re: Re: Help with fasteners in reply to F-I-T, 12-14-2003 17:05:49
Frank, I usually like the aluminum as they do install easier. They will hold fine.. We use a lot of those at work.. The only problem with the aluminum is they don't like a lot of installations & removals as they do strip out with use.. The only problems you might have is after some panel vibration over time the Riv Nuts could become loose in the holes then they are a real bear to remove the bolts as they could turn in the holes..
~I don't know what type of brackets you have but is it possible to weld regular nuts on the back as that is always a good solution [if you have room & access to the rear]..
~If you are looking for a perfectly flush panel fit you might look into Nut Serts.. Those Riv Nuts are better if you want a little air gap to the brackets.. They do make flush mount Riv Nuts but those take a rather large counter sink of the local area..
~Another option [if all your holes are close to the edge of the brackets] is to use J nuts [like the ones that hold the panels on your 955] most autoparts stores carry those in about any small size [3/16". 10 mm' 1/4", 5/16" etc.]...
[email protected]
F-I-T
12-14-2003 20:02:09
 Re: Re: Re: Help with fasteners in reply to Clooney , 12-14-2003 18:55:50
Thanks Clooney. It's on my VAC (side panels and stuff), and I'm using j-nuts right now, and they'll be fine. I was just thinking that to have the Riv-nuts or Nut-serts would clean it up just a bit. Now that everything is painted, I probably won't bother welding nuts on the back, but that's really what I should have done. I'm still learning!
Frank
Clooney
12-14-2003 15:13:27
Frank, there are many versions of those expandable nuts.. The ones I use most are called NUT-SERTS & RIV-NUTS.. Just run an internet search & for NUT SERT or RIV NUT & you will find plenty of those along with other similar types...
John Ne.
12-14-2003 15:08:41
They are also sold under the name Riv-nut, come with a handy tool to install them, go slow and do it right or you'll be pulling your hair out. John in Nebr.
Mike M
12-14-2003 15:06:52
You might try a body shop supply. Our body shop has one and it is called Gripsert I think Curtis
sells them.
