You say it'll sputter and die, under 1500rpm? Diesels don't do that. Perhaps modern ones with a lot of electrical computer controls, but olderones like the 4020, once running, only require fuel---you can run them just fine with the electrical system switched off. This sounds like a GAS tractor. When the engine idles below 1500 rpm, the generator or the alternator(whatever it has) are not puttin out enough juice to run the electrical system or charge the battery. Hence, it will start with a jump from another battery or from a "booster", and as long as the engine is running fast enough, the generator/alternator is producing enough juice to power the the distributor and keep the engine running. Below 1500rpm, and with a weak/dead battery, it doesn't produce the necessary volts and amps and the engine dies. Check the battery first, at someplace that provides load testing. If the battery checks out, check the belts on the Gen/Alt. If they are loose, tighten them. Next, I'd have the Gen/Alt TESTED, the same place that tested the battery can also do this. I'd also check the voltage regulator at the same time I had the rest tested. Just my thoughts. Good luck!
