4010 PTO spins while driving
Farmer Jack
12-14-2003 08:45:12
My 4010 pto spins while driving around. It seems most noticeable in 8th. It is not turning at 540, but at 30-40 rpm? What would cause this and how can I fix it so I can transport pto equipment without having to disconnect the driveline? I hook a post hole digger to it and I will slowly turn the auger as I am traveling down the road in 8th gear.
Thanks,
JDave
12-14-2003 10:06:10
 Re: 4010 PTO spins while driving in reply to Farmer Jack, 12-14-2003 08:45:12
The pto lever on the 10 series has a spring loaded detent that you have to overcome to apply the PTO brake if this detent is rusted--stuck you can't pull it back far enough to apply the brake --could be linkage worn---out of adjustment---or the PTO brake is worn out---means split to repair
Wayne in Tn.
12-14-2003 09:39:07
Can you stop it from turning with your hand or a glove? If so, its probably only thick or cold oil causing it to turn when not in gear. I have had lots of Dubuque 2 Cyls. that do this. If you don't like to see it turn, put a pin through it, attached to a short length of small chain.
But all the above information may be incorrect if you have a shifter problem, causing it to stay part way in gear. Usually you can stop them by hand, if its only cold and thick grease, causing it.
Bob
12-14-2003 11:32:29
 Re: Re: 4010 PTO spins while driving in reply to Wayne in Tn., 12-14-2003 09:39:07
You are kidding, aren't you, advising someone to try to stop a dragging PTO shaft BY HAND?
Good grief!
Wayne in Tn.
12-14-2003 12:17:15
 Re: Re: Re: 4010 PTO spins while driving in reply to Bob, 12-14-2003 11:32:29
Good Grief! No, I'm not kidding. I am not familar at all with a 4010, but on a 430 or 420 if you know the lever is out of gear, but the pto is spinning slowly, I did mention using a glove, but I stop them all the time with a bare hand, because its only the cold oil making it turn.
Bob
12-14-2003 14:45:53
 Re: Re: Re: Re: 4010 PTO spins while driving in reply to Wayne in Tn., 12-14-2003 12:17:15
The PTO is running because the dual plate clutch on the engine flywheel is defective, or mis-adjusted, and/or the PTO brake (wet) is shot or the linkage is mis-adjusted. I just can't imagine anyone wanting to grab that PTO shaft, much less with a glove. If the glove were to wrap around the shaft, the results would not be pretty!
Wayne in Tn
12-14-2003 16:10:57
 Re: Re: Re: Re: Re: 4010 PTO spins while driving in reply to Bob, 12-14-2003 14:45:53
Bob, I see you are safety concerned and that is fine. I will try to make myself more clear, I meant to use the glove in your hand to test the PTO shaft, not on your hand. Its just that I have had so many Dubuques that turn slowly when not in gear, I am used to them. I should not have got into this discussion, because I don't know one thing about a 4010. Have a Happy Holidays, and if my post bothered you, maybe this will make it satisfactory. Wayne.
Bob
12-14-2003 18:53:29
 Re: Re: Re: Re: Re: Re: 4010 PTO spins while drivi in reply to Wayne in Tn, 12-14-2003 16:10:57
Wayne, your post sure didn't BOTHER me, and in no way did I mean to belittle you!
I was just thinking of a newbie reading the post, and not being aware of the power in that PTO shaft behind an 80-something HP engine.
Several times over the nears I have put a gloved hand on a turning shaft, and felt it almost catch. This has scared the HECK out of me, and I'm very cautious about such things, now!
I post from time to time on this board, and hope that I may have helped someone out in some small way. I have witnessed too many accidents around machinery, and tend to get caught up worrying about safety. The heck of it is, no matter how carefull we are, there's always something a guy can overlook that can hurt us!
Anyhow, the best of wishes for Happy Holidays, Wayne!
