JD 50 still wont run
Fred
05-28-2002 08:58:14
I have an ignition problem on my 50. It has not run in a few years,and I changed the pts and cond and re-try it,I get no spark and the resistor smokes a bit on the side of the dist.I have replaced all components INcl res. getting propoer voltage at wire from sw.What else can I do,I would love to get this guy back on track. your input is appreciated.
JDM Guy
05-28-2002 12:49:21
 Re: JD 50 still wont run in reply to Fred, 05-28-2002 08:58:14
What about fuses? I had an engine that would never run. Found out that it was a fuse for the ignition.
Clooney
05-28-2002 09:55:55
Fred, see if you show close to battery voltage at the points stud inside the distributor, [with the points open]. If you don't, you probably have a short to ground at the point attaching stud.
~By you saying "~resistor smokes a bit on the side of the dist~" makes me think you are working with a Wico distributor, if it isn't, then someone probably added a resistor. If the points are grounded [easy to do if the wires & washers aren't installed properly on the points] you won't have a spark.
~If a wico dist, be careful as that resistor burns up easily.
~If you have battery voltage to the points see if it goes to under 1 volt with the points closed, if not you have bad or corroded points..
~If all ok there your problem is elsewhere, like a bad coil or distributor ground.
Fred (for DAve)
05-28-2002 11:17:42
 Re: Re: JD 50 still wont run in reply to Clooney, 05-28-2002 09:55:55
yes,it is a wico and I know the resistor is fussy,but seems no matter what it is not happy. I will have to keep looking.WHat can I use in place of the resistor if i have problems
mike
05-28-2002 18:19:48
 Re: Re: Re: JD 50 still wont run in reply to Fred (for DAve), 05-28-2002 11:17:42
Find a used delco dist. and put it on it is the best set up.
mike f.
05-28-2002 19:43:18
 Re: Re: Re: Re: JD 50 still wont run in reply to mike, 05-28-2002 18:19:48
I have a used delco distributor I will sell if you need it, I would find a deep ditch for the wico dist. a mag will work, but they primarily are not on the number tractors, let me know if I can help more.
