Broken water drain plug... G
burns
05-28-2002 08:55:05
Yesterday was one of those days which ended by me braking the square head off of the water drain plug in the head on my G puller. This is the very same plug I had out 4 days ago. Yes, I was going the right direction.
Anyhow, I don't want to reinvent the wheel so I thought I would ask if anyone has found a "easy" way of getting the old plug out.
russ
05-29-2002 11:05:37
 Re: Broken water drain plug... G in reply to burns, 05-28-2002 08:55:05
drill a hole in it and use a easy out to back it out.you may want to heat around the plug also.
G-MAN
05-29-2002 07:36:17
Burns, you can try heating the remains of the plug red hot. Allow it to cool thoroughly and you might be able to use a sharp chisel to turn it out. I've never had a pipe plug I couldn't get out with a torch - the tapered threads along with the shrinking effect of the heat/cool cycle will usually allow you to turn it right out - sometimes with your fingers. Good luck.
Jack
05-28-2002 13:04:35
Hey Burns,I had a 52 G with the same problem and someone before me threaded the lower water pipe and put in a fitting.Works well so far,and no leaks.Hope this helps.
