JD60 Exhaust Manifold Leaking
Dennis K.
05-28-2002 07:13:43
Had to pull the exhaust/intake manifolds on my dad's 1952 JD60 due a leaking exhaust gasket and found erosion on the gasket seating surfaces on both the manifold and head that will prevent any seal. Is there any way to repair the surfaces? Had someone mention about using JB Weld as a filler and filing it flat, even had one mention about using JB Weld during reassembly (that would make the next disassembly a little hard). Any suggestions or experiences? Thanks.
JDM Guy
05-28-2002 12:58:09
 Re: JD60 Exhaust Manifold Leaking in reply to Dennis K., 05-28-2002 07:13:43
A leaking exhaust manifold really doesn't matter. If it's the intake that's another story but exhaust I wouldn't worrie about.[unless it's a big big hole] My 51 M has a hole in the manifold and it seems to run ok, well it did. But if it really needs to be fixed take a look at the articles section of this web page and read the manifold repair.
Dennis K.
05-30-2002 06:23:49
 Re: Re: JD60 Exhaust Manifold Leaking in reply to JDM Guy, 05-28-2002 12:58:09
Thanks for the input.
