Finally got my 50 shifting fixed
JDman
05-27-2002 20:07:54
My 50 wouldnt shift into the whole left side 3, 5, 7. It was running fine. Then the tractor wouldnt start (Think its Starter) so we pull it out of the shed and it starts so Im going to shift and all the gears work and still work.
Cool huh!
David H. Ransom
05-27-2002 20:33:46
 Re: Finally got my 50 shifting fixed in reply to JDman, 05-27-2002 20:07:54
I hadn't known that JD offered a 7-speed transmission on the 50. Thank's for that trivia. The 50 I'm banging on has only six forward speeds (and one reverse).
Rex
05-27-2002 20:51:48
 Re: Re: Finally got my 50 shifting fixed in reply to David H. Ransom, 05-27-2002 20:33:46
David 7th was added in 1954 on the 50 Deere for freeway driving. Best used with 2row equipment.
David Ransom - Thanks
05-27-2002 21:27:13
 Re: Re: Re: Finally got my 50 shifting fixed in reply to Rex, 05-27-2002 20:51:48
The one I've been banging on is a 1953.
dl
05-28-2002 06:13:06
 Re: Re: Re: Re: Finally got my 50 shifting fixed in reply to David Ransom - Thanks, 05-27-2002 21:27:13
My B has 8 gears if you count reverse and neutral!
