'49 JD B stops running.... new coil?
Hans
05-27-2002 09:46:59
Lately I have noticed my B not popping as it should, as if it misses sometimes. From what I have seen so far, it seems to get worse the longer I use the tractor (and it gets hotter). Eventually the tractor runs so poorly that is hardly able to move itself. Last time it did this, I shut it off, and tried starting it back up - it wouldn't start. Spark was weak even with new plugs and still wouldn't start. The next morning I went out to crank it up and it started up with no effort. The points were replaced last year. Is it possible that this is either the fault of the condensor or the coil? Replacing the condensor is fairly cheap, so I'd probably replace both if necessary. If you do think that my problem is with the coil... is it worth it to get a "HOT" coil over a standard one? My tractor is mainly used for medium farm work... plowing, discing, and bush hogging, but I do like to have all the power I can get.
Thanks in advance!
Hans
Pat
06-28-2004 12:21:06
 Re: '49 JD B stops running.... new coil? in reply to Hans, 05-27-2002 09:46:59
Hi Hans - I have very similar behavior on my JD riding lawn mower - have you gotten any feedback from anyone? Thanks
