620 Carb
Steve
05-26-2002 19:58:42
I have a major problem with the carb on my 620. I noticed that some gas was leaking down the bowl. So I removed the bowl and replaced the bowl gasket. Well, when I put the bowl back on, like an idiot, I over tightened the bowl nut and broke off the threaded piece that the nut threads on to. Does anyone know if that piece threads up into the carb itself or is it actually part of the carb? If it will screw out I can maybe replace it. Anyone know where I can get a new piece? If it doesn't screw out I have no idea what to do. Anyone have any suggestions? Please help! Thanks in advance.
J P
05-27-2002 18:20:48
 Re: 620 Carb in reply to Steve, 05-26-2002 19:58:42
I just had the same problem with the carb on my 50,(DLTX75), sent it to Burrey,s Carb. Repair, can let you know in a few days.
SEAMO
05-26-2002 21:32:17
The threaded part is part of the carb main body. Several of the carb guys say they can weld new threads on the bottom. I have had several carbs in that have been repaired. They all have had problems with the load jet seat getting turned in the body. I think when they weld the threads back it shrinks the press fit on the seat of the main jet. SEAMO
