Mt mower
barry eliason
05-26-2002 15:31:39
hi, looking for a mower to fit my mt.
Ralph Ia
05-27-2002 19:29:26
 Re: mt mower in reply to barry eliason , 05-26-2002 15:31:39
Barry, if you look in todays classified ads there is a #51 mower that fits the M and MT. Its located in Wisc.
barry eliason
05-28-2002 07:35:38
 Re: Re: mt mower in reply to Ralph Ia, 05-27-2002 19:29:26
hi, i guess i should have said i'm near k.c. mo. thanks barry
Dan
05-26-2002 20:41:55
If your mt has the regular type lift in back, the round bar with lift arms, a number 5 opr #8 will work. You have to have the quick tatch type mount on the #5 and it has to be the right one for the MT, on the #8 you can space in the mounting brackets to hook up on the bar. You also need to anchor the lift arms on the side, with the spring pins and generally a bolt in each side also then you can use a cable lift to raise the sickle bar. There may be other mowers that fit but those are the 2 I have used on my MT.
