520 Runs Very Rich
ET
12-14-2003 05:23:12
I need some ideas on what to look at on a 520 that suddenly started to run very rich. The tractor starts hard, floods easy, once its running it smokes a lot. The spark plugs are fouled black and fuel consumption is way up. My first reaction to this tractor was the obvious carburetor problem. I rebuilt the carburetor and found no real big problems. The float was ok but the leval was a little off. I made sure the choke was not damaged or put togeather wrong so its not coming on. I'm leaning toward weak spark, but the coil is not to old. The only other thing I can come up with is an air restriction in the top of the air filter. If anyone has any more ideas I would like to hear them. T may be passing over something very simple. Thanks Eric
Clooney (rich running)
12-14-2003 06:32:48
 Re: 520 Runs Very Rich in reply to ET, 12-14-2003 05:23:12
ET, your statement "~that (it) suddenly started to run very rich".... Says it probably isn't the air cleaner unless it sucked in a rag or hornets nest...
~It probably wouldn't hurt to run it with the air cleaner intake pipe disconnected just to eliminate that as a possible cause..[a plugged air cleaner would be high on the list]
~You could have a weak ignition system but that usually causes hard starting or misfiring under power.. [don't rule it out but it wouldn't be high on my list]..
~One thing to look at & that is the possibility of the crankcase being full of gasoline due to a leaking oil pressure controlled fuel shut-off diaphragm.. [if the crankcase has gasoline in it, it can get by the rings & cause all kinds of rich running problems]...[that's a common problem]
~A choke malfunction would be the obvious but you say that is under control so it must be something else..
~Basically, if it's getting plenty of unrestricted air & has a good spark it must be getting extra fuel from somewhere.. That is either the carb or the crankcase..
~Are you sure it's a gasoline induced rich like black smoke? If your richness has a blue tint to it suspect a failed [or failing] crankcase vent pump that's pumping oil into the air intake...
~You might want to do a spark test to see if you can find a problem there.. To do that ..Take an old [known good] spark plug, then open the plug gap to 3/16", then install that in one plug wire at a time & lay on the engine block, then crank the engine [or actually run it on the other cylinder] & see if you are getting a bluish spark that jumps that 3/16" gap multiple times in a row.. If the spark is weak looking or yellowish make sure the points are set to .022" on the high part of the points cam & not burnt looking, make sure that the condenser is good & has a good ground connection, & that the ign wires aren't old cracked looking & are solid metal core & not automotive TVRS carbon core..
~One more thing to try... That is to set the manifold heat control to HOT.. If it's set to cold & you are running your tractor at lower ambient temperatures you could be getting carb icing or poor fuel atomization..
~Post back or E-Mail with any questions....
[email protected]
