Have some questions about a noisy 4020 hydraulic system. Looked through the archives but really didn't see much there about this noise. I rebuilt the pump. The bearings were so loose you could bare handed feel the play after removing the worn out coupler. Outside of the loose bearings (which adjusted up just fine) & leaky seal, didn't find anything wrong with the pump but it still makes LOTS of noise but only when idle (new drive coupling too). While it's lifting something (remote or rockshaft) it is virtually silent. I suspect the noise is sroke control related. Yesterday however I noticed that this same type of noise is comming from under the dash. That made me think.... Is there any particular "thing" under the dash likely to be causing the pump to rapidly keep changing it's idle/pumping state (in & out of stroke)? Could a minor problem in the load circuit be the cause of all the racket & it only sounds like the pump is the problem? To you guys these probably sound like dumb questions but all my tractors go putt putt putt while this one belongs to my nephew. Settings were made with JD "special tools". Pressure is on the high side but is within spec limit. Never lacks for power or speed and after I rebuilt the steering unit, that too works great. Outside of the noise, the only odd thing it does is if braking, turning & lifting remote & rockshaft all at the same time, occasionally (less than one out of ten times) you may feel a slight "bump" in the steering. Like for a small fraction of a second there was no PS. I just assumed it a mommentary loss of pressure created by the full demand on all appliances. One other little bit that makes me think it might be a load circuit type of problem is that in the winter it's nice & quiet until it warms up. Doesn't leak fluid (at least not outside), lift arms begin to rise as soon as you begin to crank the engine & they take well over a day to fall. This is a VERY early 4020. Example... the part number for the high pressure line from the pump to the dash board of a 4020 will not fit this tractor but the line from a 4010 fits perfectly. Also has O rings in the remote couplers instead of V seals. V seals leak but it is & always has been a 4020. You guys have any suggestions as to what to do or look into next? Thanks & have a great Memorial Day.
