Adjusting new clutch
JD60
05-24-2002 07:54:01
I replaced numerous components in the pulley wheel, now I just have to put it back together, what is the best method for setting the clutch ie. the 3 nuts?? is there some technique???Thanks!!
Bill Hires
05-24-2002 09:07:41
 Re: Adjusting new clutch in reply to JD60, 05-24-2002 07:54:01
Place the clutch operating lever in the engaged position(lever fully foreward)and tighten each adjusting nut a little at a time and to the same tension. Check tightness of clutch after each adjustment by disengaging and reingaging clutch. When the adjustment is correct, a distinct snap will occur when the clutch is engaged using 40-60 lbs. pressure at the end of the operating lever to lock the clutch in the engaged position with the engine running at idle speed.
JD60
05-24-2002 21:14:15
 Re: Re: Adjusting new clutch in reply to Bill Hires, 05-24-2002 09:07:41
OK, i did it the other way...disengaged tighten until stop, then backed out 1 1/4 turns....now, would this way create a situation that would cause a clanging noise 60% of the time in the disengaged poistion, but goes away when engaged???
When i had it apart, I noticed cotor pins through the 3 studs, are these supposed to hold the doublesided clutch disk or something???
F-I-T
05-25-2002 07:36:22
 Re: Re: Re: Adjusting new clutch in reply to JD60, 05-24-2002 21:14:15
JD60:
No, the cotter pins just hold the studs so that they won't slip toward the underside of the pulley. The dogs and toggles could disengage if they did. The double-sided clutch facing just slips onto the pins and floats.
I think your clanking noise is from the floater disk (the cast one with the gear teeth on the inside) slopping against the teeth of the driving disk. Most I've heard make kind of a tinkle sound. It's really more annoying than problematic, but to get rid of that noise, you'd have to replace the worn part or parts. As long as the clutch works properly, engages/disengages smoothly, and does not slip, the floater disk will "get together" with the driving disk as the clutch engages, and will work fine. The trouble can come when the floater is so sloppy that it can wear a small ridge on the driving disk teeth and cause the clutch to hang up a bit.
Frank-in-Tallahassee
70D // 855
F-I-T
05-24-2002 08:07:13
JD 60:
Some folks use a common torque value to bring all the nuts up to the same force and position. If you have a torque wrench handy, and all the studs have clean threads that might work fine.
But I've just always turned the nuts on as evenly as I could, so that I judge that they're all holding the same amount. You can even look at the studs and sort of judge if you have one on a turn or two more than another. Then I turn them in pretty much as far as they will go , and then start backing them out evenly. Then I generally go too far out, and make my last move inward which is the best way (so the last move is toward the work). That's just a habit of mine to keep the play to a minimum.
Sounds like you're on the home stretch !
70D // 855
