Clooney/John T --M over heating??
39B
05-23-2002 18:11:04
I have a 51 john deere M that we recently purchased. The tempertature gauge goes from cold to Hot in about 10 minutes. The man we bought it from said that doesn't actually overheat. Said something wrong with the placement of the gauge. What could be the problem. is it a major problem or minor. COuld it just be the gauge or is it overheating!! Thanks
John T
05-23-2002 22:44:14
 Re: Clooney/John T --M over heating?? in reply to 39B, 05-23-2002 18:11:04
If shes not boiling out coolant or loosing it otherwise, its probably not really overheatign as bad as the gauge indicates. If she is overheationg, I have seen them build up corrosion and rust and scaling and flakes around teh cylinders in the water jacket area causing that problem. If it hasnt been done lately, I would give teh whole system and radiator a good flushing out and cleaning and see what happens, but if shes not boiling out you may not even have a problem in teh first place other than an incorrect gauge (which I have seen plenty of) Ol John T in Indiana
Clooney
05-23-2002 18:25:31
39B, there was a known temperature gage inaccuracy on the "M" that was fixed on the later 40's. The gauge did tend to read high on some of the "M's".
~Is it boiling over? If not it is probably the gauge.
~The M, as well as other numbered series Deere's were thermo-siphon cooling & didn't use a water pump. The use of antifreeze in the cooling system was not recommended by Deere as it effected cooling. Most people including myself use antifreeze, but it should be used in as little a percentage as possible that will protect for the weather in your area.
~Try running your tractor with only water to see if that improves the gauge reading, if so use less antifreeze.
Kerry
05-23-2002 21:03:51
 Re: Re: Clooney/John T --M over heating?? in reply to Clooney, 05-23-2002 18:25:31
My grandfather had an old MT that I fixed up when I was a kid (14 or 15). Just curious, if Deere recommended NOT using anti-freeze, what did farmers do in the winter if they needed to feed or something else (plow snow? Not in TX, but surely up north) with their tractors during the winter? Did they drain and refill the water every day?
Was this recommendation the same with the other letter-series tractors without water pumps?
Kerry
mike
05-25-2002 04:55:43
 Re: Re: Re: Clooney/John T --M over heating?? in reply to Kerry, 05-23-2002 21:03:51
They used methanol,but it requires a special gauge to check and it has to be checked and readded as it tends to evaporate off. I living up north would worry alot more about a less than 50/50 antifreeze mix than I would the temp. gauge reading on an M JD. There are lots of two-cylinders up here in Ohio and I have seen lots of damage caused by freezing and breaking engines but can't place any to overheating.
