B Transmission bearing problem
JD JACK
05-21-2002 19:25:20
I am working on late model B serial #201000-. The bearing cups for side differential would spin in qiull (part# b2332r). I installed new new cups and
they also fit loose. They will spin around and can be pulled out by hand. Is this normal? I cup just going to spin on quill? Should i get different qiulls? Thanks
ChuckW
05-22-2002 09:14:40
 Re: B Transmission bearing problem in reply to JD JACK, 05-21-2002 19:25:20
I may have a couple of these. Would you be interested in purchasing if I have available?
Mike H
05-21-2002 20:07:28
They should NOT spin,replace the Quills or use some red loctite #271
