B leaking around push rods
Tom
05-21-2002 18:19:00
Whats involved in replacing pushrod seals in a 49 B?
Thanks
Tom
JDRegg
05-24-2002 20:26:20
 Re: B leaking around push rods in reply to Tom, 05-21-2002 18:19:00
Hey Tom,
I have the tool and pics of it, to remove the tubes. Let me know if you have done this yet and I'll send you the pics.
Seamo
05-21-2002 20:39:14
Most of the heads I have worked on here in Illinois are limed up around the tubes.AfterI remove the tubes I use a torch to heat the lime deposit. It pops loose real easy then . The other caution is make sure your bushing driver isn't to big on the od it will tear up the hole in the head. Note that the tubes are bigger on one end. Take sand paper and gently clean the holes on both ends of the cyl head. Apply a good sealer on the head and on the tubes and gently tap in place. Earl
John T
05-21-2002 18:28:24
If youre referrign to the pushrod tubes and water leaking through or around them, you basically have to remove them and install new ones. One tip when inserting the new ones I use, is to place them in a freezer for an hour or better before you install them and a proper size bushing driver is a must. Ol John T Nordhoff in Indiana
Green_in_MI
05-22-2002 18:38:38
 Re: Re: B leaking around push rods in reply to John T, 05-21-2002 18:28:24
John T
Can antifreeze enter the cylinder through the pushrods tubes or is antifreeze in the cylinder only the result of a cracked head?
Tom
05-23-2002 15:10:40
 Re: Re: Re: B leaking around push rods in reply to Green_in_MI, 05-22-2002 18:38:38
From what I have been told, Radiator fluids are leaking through the push rod seals. But I'm a little foreign to Green Tractors, someone else could answer this question a little better.
Tom
Tom
05-22-2002 11:43:16
Is it a must to pull the head? Or can it be done with a puller of some type?
Tom
