Single front wheel bad for plowing??
720 question
05-21-2002 17:04:20
is a single front wheel bad for plowing. How rare is a 720 diesel with a single front wheel. Would this be a good tractor to pull plows with??? thanks
phil
05-22-2002 08:12:00
 Re: Single front wheel bad for plowing?? in reply to 720 question, 05-21-2002 17:04:20
I like a narrow front for plowing because it makes nicer turns. With a wide front you have that outboard front wheel swinging around the turning radius. With a narrow front, the turn radius is nearly the same as the rear wheel spacing.
Dan
05-22-2002 07:34:05
The single front wheel as said is great for row crop work. For plowing I would prefer a wide front as you can run the front wheel in the furrow and helps to keep it in line. Other problem with single front wheel or 2 front wheels together is that if you hit a large sod or something like that, and if you don't have power steering, the front wheel can turn rapidly so the steering wheel does also. With a spinner knob on it it can hit ya several times before it stops. Power steering dampens that. Problem with a wide front is that if you don't have power steering they steer a bit hard. At least in our area I think the wide front is the most versitle. The single front wheel should work for plowing, may have to use the brakes more.
CLW
05-21-2002 20:20:35
The single front wheel was great for row crop as it would run in the middle of the row very good. I don't know why it wouldn't work for any type plowing. They are not rare in that you will make a lot of money off one. The front pedestal can be changed easy on the 720 so it's hard to know what came on your tractor.
CLW
CLW
05-21-2002 20:18:51
CLW
