JD w/Hyd FWA will not dis-engage with clutch pedal
Paul
05-21-2002 16:40:42
I am trying to trouble-shoot the above problem on my 4020. When the clutch pedal is pushed in, a pressure activated switch on the clutch valve housing is suppose to de-activate a solenoid thus turning off the hyd FWA. I replaced the switch and checked it but it remains a closed circuit with either the clutch pedal out in or out. My reasoning is that with the clutch pedal in, the
pressure in the valve body should drop thus opening the switch circuit. Anyone have any experience on this problem? If so, your help would be appriciated. Thank. Paul
