John Deere Model M
George
05-20-2002 13:23:11
This weekend I started cleaning up our old model M. The hood is in good shape but has rust pits. Is bondo a common practice for filling when restoring a tractor? Is there a better way of filling the rust pits?
josh
05-21-2002 08:11:59
 Re: John Deere Model M in reply to George, 05-20-2002 13:23:11
dont use bondo. if you take it to any body shop and they mite do it for you
Bus Driver
05-21-2002 17:57:22
 Re: Re: John Deere Model M in reply to josh, 05-21-2002 08:11:59
The rust must be eliminated no matter the method chosen to fill the pits. Bondo makes an epoxy based filler that is not usually in stock. Ordinary Bondo is polyester. Epoxy has about 5 times the bond strength. Much less likely to crack. Maybe the supply house will order the epoxy based filler for you. JB Weld is epoxy but tends to melt with the heat of sanding. Bondo uses different fillers from JB Weld.
JDM Guy
05-20-2002 14:37:31
Ya I used alot of Bondo on my M hood, grill and air stack. It works good but if you hit it or use it in an area were it gets hot then it will crack.
