Hydrolic steering rebuild
Rick
05-20-2002 10:09:42
My 3010 JD has a very bad hydro leak coming from seal under the steering wheel. I have it torn apart and seal kit bought but am wondering about doing a complete rebuild on the steering box, but I don't have a digrahm for all the seals if anyone has this and can post it for me I would be very greatful Thanks to everyone and God Bless
DON IN ILLINOIS
05-21-2002 06:09:48
 Re: hydrolic steering rebuild in reply to Rick, 05-20-2002 10:09:42
THE STEERING VALVE MUST BE TORN DOWN FROM THE BOTTOM UP TO FIX THIS PROBLEM. YOU CAN REPLACE THE SEAL UNDER THE STEERING WHEEL BUT THE PROBLEM IS AN O-RING JUST ABOVE THE CYLINDER PART OF THE VALVE. YOU NEED A DIAL INDICATOR TO SET THE VALVES AND A SPECIAL TOOL AS WELL. THIS IS NOT A JOB FOR THE AVERAGE PERSON TO DO AS THE VALVE SETTINGS ARE VERY CRITICAL WITH .001 AND .003 CLEARANCES.HAVE YOUR JD MECHANIC DO THIS FOR YOU. DON
