JD 2010 Three Point Hitch Troubles
BOB
05-20-2002 04:48:52
I have a '64 2010. The hitch would not work, so I pulled it apart, and replaced every o ring, seal, piston seal, etc. according to the service manual. It came up when the tractor first was started, but now only comes up once in a while....seems to hold up when it does come up, when you let it down, it will come up when it wants to...could be hours. I cleaned the filter, and there is plenty of fluid...Any Ideas!!!
Tim in Ct.
05-20-2002 05:39:25
 Re: JD 2010 Three Point Hitch Troubles in reply to BOB, 05-20-2002 04:48:52
Forget cleaning the filter, get a new one. My 61 2010 had problems and I kept trying to clean the filter. It looked good but just does not allow the oil to flow. You can read a newspaper through the new one.
Joe Stewart
05-20-2002 05:33:52
I was having similar problems with my 2010. I soaked the filter in carburetor solvent on at least three occasions, each time leaving it soaking for a couple of hours. It sure looked clean to the naked eye, but each time when I re-installed it, the 3-point (and my power steering) would not work. I was getting prepared to purchase a new remanufactured hydraulic pump when somebody suggested that I replace the hydraulic filter with a new element. I bought one at John Deere ($55) and the hydraulics work great!
Steve in Tennessee
05-20-2002 18:44:48
 Re: Re: JD 2010 Three Point Hitch Troubles in reply to Joe Stewart, 05-20-2002 05:33:52
I've similar problems with my 2010. I've yet to replace the filter, but I've washed it out about twice a year and replace the whole 8 gallons of hydraulic fluid each time. The $55 filter change sounds cheaper by the minute.
