JD 50
big john
05-19-2002 18:04:07
Can someone explain what the Powertrol feature on a JD50 means, it appears to be a hydraulic pump. In addition on the JD50 tractor that I looked at there seemed to be a set of shafts on either end side of the seat, was this for a three point switch.
Steve - IN
05-20-2002 19:45:37
 Re: JD 50 in reply to big john, 05-19-2002 18:04:07
big john,
Looks like your question got passed by. So from the humble owner of a 60 -- bigger brother to the 50 -- here's a short stroke answer.
1. You're right. Powertrol is basically a hydraulic pump. The pump itself is located to the left front of the cockpit, above the flywheel. There's an on / off "switch" on it. The up / down control is a long bar to the right of the seat. There's a slow up, a fast up, a neutral and a slow down, fast down position -- five notches in total.
2. Right again. Those horizontal shafts under and behind the seat are meant to raise and lower a 3pt hitch. In full battle gear, the shafts are connected to two horizontal bars at 90 degrees which are in turn linked to two vertical adjustable shafts which connect to the two horizontal draft bars that pull and lift the implement. Raise the bar to the right of the seat and the shafts under the seat turn clockwise. Lower it and you get counter clockwise. In the center of all this, there should be a horizontal hole meant to accept a top link to stabilize and ideally regulate on the vertical plane the work of the two draft bars down below.
This whole 3 point set up is the brain child of a manic depressive Irishman who died of a self inflicted drug overdose named Harry Ferguson. IBM used to run a nifty site where you could read the original patents. This has now passed to www.delphion.com where they require a proctologist exam for admission. From memory, the Powertrol on the 50 wasn't the full embodiment of the patent, nor were many others. It's a little odd that this became a standard until you consider the weight of numbers given by a guy named Ford who was Ferguson's partner for a while. Then again, who am I to judge, my ancestors came from around Stuttgart, where they have little respect for tragic / poetic Irishmen
and generally favor efficiency, arrogance and overpriced iron. That may be why my ancestors migrated from Swabia to Indiana.
If you're considering buying that 50 -- rest assured you can make it into a 3 pt hitch machine. Pricey if you go original set up, less pricey if you use aftermarket parts. With a 3 pt, it will run most any modern implement withing power restrictions of the 50.. and just spending time on one of those machines will generally lower your blood pressure, and better your outlook on things while extending your life span. Now who sounds like an Irish poet?
Good luck in your exploration of tractors.
Steve
