401B JD = What?
kb
05-19-2002 16:47:09
I looked at a 401B at a dealer today (they were closed). This machine shows just over 1300 hours and has a label indicating it belonged to the US Corp of Engineers. From the looks of it I do not see the normal signs of abuse and excessive wear, so the hours may be pretty accurate.
The tractor does have a dozer type blade on it. The blade frame bolts to the drawbar at the rear, and also where I believe a bumper would bolt on the ag version. All the hydraulic lines appear to be quickconnects. I wouldn't anticipate removing the blade a huge undertaking.
I have two questions about the tractor that you all may be able to help me with. First, what ag version is the same as the 401 B (I realize the front axles will be completely different)? I've seen the 2030 mentioned, as well as the 2440.
Second, the tractor has really small rear wheels, the tires are 12.6(?)X24, it sure seems the ag version would have had something like a large 28" tire. What size tires should be put on it to bring it closer to the ag version?
BTW, this tractor is an 8 speed with gas engine. It has the PTO, and the clutch feels like a two-stage; plus has three-point hitch. If it runs as well as it looks this old gal has the potential to make a fine tractor for use on the farm, but I want to make sure parts can be readily found for her.
cannonball
05-20-2002 06:26:03
 Re: 401B JD = What? in reply to kb, 05-19-2002 16:47:09
i have a 401B diesel it is about the same as 2440 with the exception being industral..my has 8 speeds with reverser..has 8 forwards and 8 reverses...it has 62 hp..use it to run a 9 ft khun disc mower on it...it has 16.9 28 tires on back...it is a good tractor and it is not live pto ..mine has a form of 2 stage clutch ..the first stage is just stopping the fluid to the reverser and push in futher down and change gears and put pto in gear..love not having to shift gears to get reverse.....mine had 1742 hrs when i bought it...1981 model.need move inf e-mail me
kb
05-20-2002 09:45:22
 Re: Re: 401B JD = What? in reply to cannonball, 05-20-2002 06:26:03
Cannonball, thanks for the info. This 401B doesn't have shuttle shift, I think it has the Hi-Lo 8 forward-2 reverse tranny. It only shows just over 1300 hours, if the proofmeter is working. I may have more questions, and hopefully some answers, after I go to look at it this evening.
