JD111 clutch will not disengage
Carol
05-19-2002 15:48:44
hi all --
The clutch on my JD111 will not disengage. I pushed it in, the pedal has stayed most of the way down, and it will no longer go into any gear. I am not mechanical, but would be willing to whang on something or push something -- but WHICH item to whang or or push?
Ralph
05-19-2002 17:39:01
 Re: JD111 clutch will not disengage in reply to Carol, 05-19-2002 15:48:44
It sounds like the belt needs tightening. If I remember correctly the idler pully is just to the rear of the engine and on the left side. I seem to remember a bit of oil (which I had previously failed to get in the crankcase) and a lot of dirt. Unless you are bent on tightening it youself I would check on the price of a new belt "installed". That, a blade sharpening and tuneup might be worthwhile. If you want more help, E-mail me, I will look at the one in the garage. It needs an oil seal and gasket and will most likely get a new drive belt.
Nathan(GA)
05-19-2002 16:44:05
I don't know about the 111, but sounds like a belt broke or come off the pulley. You could post it on the garden tractor forum.
Don't whang anything too hard!
