Jd 730 does it have pet cocks to open when starting
STEVE HACKER
05-19-2002 14:05:02
it just seems like its not turning over fast enough, its 12 volt electic start lp tractor, located in central ok. i love her when she is starting, but it is very hard to start, i grew up on an A model and we had to open the petcocks when starting it, does this 730 have the same petcocks and where are they located,,,,thx steve
G-MAN
05-20-2002 07:30:44
 Re: jd 730 does it have pet cocks to open when starting in reply to STEVE HACKER, 05-19-2002 14:05:02
I know those tractors don't have petcocks from the factory, but isn't there a place to install them? Possibly in the underside of the block? I seem to remember seeing holes in the underside of the block on my 60, plugged with pipe plugs, although I can't remember for sure - maybe I'm imagining things. Or maybe the newer number series tractors don't have that hole.
Frank M
05-19-2002 19:09:35
First tractor I ever drove was a 730 LP They don't have petcocks. They always slow down when they're on the compression stroke.
Tony 630
05-19-2002 17:17:25
Steve,
First, two possible problems. Timing is off or starter is weak.
Remedy #1: Start engine and adjust timing accordingly. Simple fix.
Remedy #2: After years of use they tend to get weaker. Just send it to a local rebuilder and tell them what it is doing, dragging e.g. and they'll get it back good as new.
Any problems just e-mail.
Tony630
David B
05-19-2002 17:11:20
No
Will P
05-19-2002 14:54:20
OK I really don't know much about the number series. But if it did. They would probably be under the tractor. That is where the late A and B have it. I really don't know, but if it did. That is where I would look.
Will P
