Engine block for John Deere 420C
Dale Aebly
05-19-2002 11:31:04
I need an engine block for a 1958 John Deere 420C crawler. The current engine was stuck so I replaced the piston, rings, etc. and noticed the block had been cracked and welded in two places. After running the engine for a short period of time, milky oil was drained from the crankcase. A good non-cracked or welded block is what I need now. The casting number of the block is M3037T. Your help will be appreciated.
Paul
05-19-2002 15:08:42
 Re: engine block for John Deere 420C in reply to Dale Aebly, 05-19-2002 11:31:04
Where are you from I have acomplete engine for a 420c will sell for 500.00 but I'm in Canada.
Paul
05-20-2002 10:54:29
 Re: Re: engine block for John Deere 420C in reply to Paul, 05-19-2002 15:08:42
I'm in New Brunswick the moter is stuck was out doors before igot it now is under cover and is complete with hydrulic pump
Dale Aebly
05-20-2002 10:15:46
I'm in Spokane, WA. Where in Canada are you?
JD40C
05-19-2002 13:48:33
Hop on over to http://www.jdcrawlers.com and give Lavoy a shout. He carries all sorts of used JD crawler parts.
