removing bearing race
Ken C.
12-13-2003 15:38:43
What is the easiest way to get the inside rear axle bearing race out of a 52 G. Got to replace the seal but can't get the race out, there is no edge to get a punch to it to hit it. Race is a little rough so i thought i would change bearing to. Any ideas would be appreciated, thanks Ken.
Jonathan
12-14-2003 08:38:23
 Re: removing bearing race in reply to Ken C., 12-13-2003 15:38:43
Another method that also requires a welder is to run a bead around the inside face of the bearing race. When it cools, you can usually lift the race out with your finger tips...The weld shrinks the race sufficiently...
Clooney
12-13-2003 16:03:36
Ken, the best way I have found is to cut a piece of steel strap [maybe 1/4"-5/16" thick] & long enough to center in the middle of the bearing race, then clean the race & tac weld that strap into the center of the race.. When the weld cools it will shrink the race slightly & you can use a long rod or pipe through the outer axle bearing area & easily knock that inner race out [try it, it works great]..
~If you don't have a welder you can use a bearing race puller from the inside then use a pipe from the outside to drive on the race puller [is the difficult way]
~Or use a long rod [5/8" concrete re-rod will work if the end is ground flat & bent] to reach in from the outside & try to get in in the bearing race cut-out slots [it is also hard to do & takes a lot of bending & re-work to get the rod to properly contact the bearing race]
[email protected]
Ken C.
12-13-2003 18:24:21
 Re: Re: removing bearing race in reply to Clooney , 12-13-2003 16:03:36
Thanks Clooney, i have a welder so i will give it a try. Sounds easy enough. Thanks again, Ken.
