Best cleaning fluid to use?
Mike P
05-18-2002 20:48:28
I'm at the point where I'm going to start re-
assembling the rear end of my "A". I had to tear it down to get at, what I discovered, a blown gasket between the hyrdraulic cylinder and the rear housing.
Now I'm going to put the whole thing back together with new gaskets and a bit of LocTite (thanks to Clooney for the pointers).
There's a considerable amound of sludge in the bottom of the housing, on the bull gears, and above the fluid level, the gear oil as condensed on the inner walls as a thick wax-
like goo. I'd like to take a little bit of time to at least clean out the gunk from the bottom of the housing.
What fluids would you recommend I use to flush this out with? My boss (who's a pit crew mechanic) recommended using diesel, others have suggested kerosene.
What are everyone else's experience?
TIA
John Mann
05-19-2002 09:21:31
 Re: Best cleaning fluid to use? in reply to Mike P, 05-18-2002 20:48:28
I recently had an engine in frame overhaul done at a reputable shop. I asked the guy about cleaning the crankcase out, he said he used a steamer and ran diesel through the soap line, he said the hot water would evaporate and the diesel would oil the metal enough to keep it from rusting. I had some doubts but when I got it home the engine was very clean and the oil never got that milky look.
Gord
05-19-2002 09:20:14
Diesel fuel or varsol would be my choice for cleaning the case out nut sometimes the only way is to use elbow grease and a scraper to clean out the crud.
I really enjoyed the pictures of your tractor. It certainly adds to the enjoyment of this site to see other tractors and projects. You must have a very good digital camera due to the sharpness of the pictures. I have a 1949 A that looks to be a close copy of yours except that it has a wide front end, magneto ignition and no fenders.
Mikey G
05-19-2002 06:45:08
Mike I use mineral spirits in a air pressure sprayer I put a pail under the drain plug hole with some cheese cloth in the funnel to strain it and reuse,when I finish cleaning I spray everthing down with Wd 40 or your choice of rust inhibitor
Mikey G
Henry j
05-19-2002 05:26:25
Mike
I don't know anything about the configuration of the gear case on the A. However, I have had to deal with that stuff you are talking about in one of the final drives on my 420. Diesel wouldn't mingle with that stuff at all for me. Fortunately I was able to get to it with a long screwdriver to scrape loose the bulk and drag it back out the back. I used carb cleaner for the final scrub out. You may have to blast something directly at the stuff under pressure. Maybe a gas bun (gun that shoots solvent with air) will have to be resorted to if the diesel won't cut it. I hope your goo is not nasty and uncooperative as the stuff I ran into. Good Luck.
F-I-T
05-18-2002 21:06:31
Mike P:
I like diesel fuel. It has an oily property so that if it gets in bearing/bushings, etc, it will loosen dirt, and wash it away, but leave an oily residue behind so nothing can rust very easily. It doesn't evaporate very readily, and if you want to strain it through some clean shop rags in the bottom of a funnel, you can use it to degrease for quite sometime.
Frank-in-Tallahassee
70D // 855
