50-shaped piece of rust
David Ransom
05-18-2002 19:49:44
I jacked the right wheel up and tried to turn it. It turned a very short distance. I think the room for movement was in the transmission or differential, because the flywheel didn't move at all. I also saw that with the clutch back, the belt pulley was turned by the back wheel. Is it meant to do that?
Fudd@Work
05-18-2002 20:32:13
 Re: 50-shaped piece of rust in reply to David Ransom, 05-18-2002 19:49:44
If the transmission is in gear and you turn the back wheel the pulley will turn. Put it in neutral and the pulley should not turn.
David Ransom
05-18-2002 20:41:36
 Re: Re: 50-shaped piece of rust in reply to Fudd@Work, 05-18-2002 20:32:13
I'm glad to know that's working right.
