Floor Pan Bolts Are Out BUT OH!!!!! MY
POPPER DICK
05-18-2002 18:25:58
Today my friend with a miller wire feed welder came over and welded nuts onto my broken off bolts for extraction. The right side bolt required two nuts be welded ( the first broke off). Lucky on the second nut for extraction. The left side bolt was married to its hole for eternity. After three nut attemtps out came the center punch and a set of sharp drill index. Drilled beginning with 3/16" and going up at 1/64 increments. Even when I reached the high sides of the hole threads those pesky little bolt theads did not want to come out. A sharp all and patience finally prevailed. With extreme caution and lots of PB Blaster I chased the threads with a sharp bottom tap and blew out the debris often with a high pressure nozzle.
The moral to this story is getting those bolts out is a real challenge. Heat did no good on this bolt.
Dick
Ed
05-19-2002 08:55:57
 Re: Floor Pan Bolts Are Out BUT OH!!!!! MY in reply to POPPER DICK, 05-18-2002 18:25:58
Sounds like a good application for Never-sieze upon reinstallation.
