?Increase PSI on 1946 B w/ powertrol
Bumps
05-17-2002 09:10:55
I have a 1946 B with prowertrol lift. Can the lifting psi be adjusted somehow? I could use a few more pounds of lifting psi for a hydraulic rake cylinder.
Thanks for any input.
Bumps
Clooney
05-18-2002 07:13:21
 Re: ?Increase PSI on 1946 B w/ powertrol in reply to Bumps, 05-17-2002 09:10:55
Bumps, to answer your question, yes, the pressure relief valve spring can be shimmed with extra washers to increase the operating pressure.
~I don't recommend it though as you risk blowing a cylinder to housing gasket [the whole rear of the tractor must come off to repair], or blowing a Power-trol housing gasket [easy repair, but still a pain] or blowing a piston sealing ring [easy repair but messy]
