JD 1010 special
wvhogleg
05-17-2002 06:51:44
i usually post on the farmall board, but i need to help a neighbor out so i am asking you fine people. my neighbor has a jd 1010 special with a wfe that he inherited from his grandfather. i wanted to find out some information about his tractor as far as hp, strong points, weak points, parts availability, wheel width adjustments, value, etc. the tractor has been used mainly for mowing fields with a brush hog. i believe it is a gas engine, and seems to run ok. he uses it now because he has it, but he has hilly fields and is considering looking at a 4x4 and departing from his 1010. thanks.
