3020 loader hydraulics
sawdust
05-16-2002 17:52:45
oh wise deere sages', today I used the tractor to level some gravel. everything worked great for about an hour and than I could not get the bucket to raise. I shut the tractor off and checked the flid level which looked a little low, which I topped off before I started the tractor. when I started the tractor there was no change with the hydraulics the only way I could raise the bucket was to flip the lever on the dash forward than reverse to get the bucket to move. however I noticed that the hydraulic control valve was leaking pretty good
I'm stumped....
gy3020
05-16-2002 18:13:17
 Re: 3020 loader hydraulics in reply to sawdust, 05-16-2002 17:52:45
Hey Sawdust,
Sounds like you have a problem there. My first guess would be to look into the possibility of a rebuild on those control valves. Sounds to me like you may have blown out an o ring on it? Thats the first thing I would check on.
gy3020
05-16-2002 18:14:51
 Re: Re: 3020 loader hydraulics in reply to gy3020, 05-16-2002 18:13:17
You might look at the lines also going to the valves. I have had those blow out on me as well.
sawdust
05-17-2002 04:32:52
 Re: Re: Re: 3020 loader hydraulics in reply to gy3020, 05-16-2002 18:14:51
thanks for the direction. I suppose thats something I don't want to do myself ?
