Follow up/ leaky pushrod tubes/setting gov bevel gears
Steven in Ice c
05-16-2002 16:37:24
I would like to thank everyone that helped me out with my tractor issues. It is simply amazing the wealth of knowledge on this forum, Mark, John T, Clooney, just to name a few. I set the bevel gears, they where kind of beat up, but not so worn that they were sharp on the ends. Needless to say I may at some point try to reset them again, or replace them. BUT they don't sound all that bad, considering they were hardly touching when I took her apart.
Took my head back to the machine shop after the pushrod tubes still leaked. They put in new tubes and usewd the blue sealer this time.Put her back together and filled up the radiator, and I heard water RUSHING into the block!! Drained the cooling system and crankcase, and pulled off the head.The parts guy gave me a BO/BR head gasket, Needless to say the water jacket lines up perfectly with the push rod valley!! Got her back together again last night, ran her no leaks. Came home from work tonight started first compression stroke over!!! Steven
38 unstyled B
