LA john deere
ben brown
05-16-2002 11:16:06
whats the valve setting on a la motor thanks ben
ROS
05-18-2002 16:32:01
 Re: LA john deere in reply to ben brown, 05-16-2002 11:16:06
If this engine has lots of hours and never been rebuilt it can sometimes be difficult to get the proper clearence. The adjuster which contacts the bottom of valve becomes worn in center causing excess clearence even when set at specks. If this is the case, adjustment will either be set with a dial indicator or by amount of turn on adjusting screw.
Steven M
05-16-2002 17:30:17
Set intake tappets with .006'' clearance and exhaust tappets with .008'' clearance when engine is hot. If tappets are adjusted when engine is cold, add a additional .002'' clearance.
jdman(MO)
05-16-2002 17:29:16
Intake .006 hot and exhaust .008 Hot. Inital setting cold is .008 cold for the intake and .010 cold for the Exhaust. Russ
